thinkgeo.mapsuite.silverlightcore.shapevalidationmode
ThinkGeo.MapSuite.SilverlightCore.ShapeValidationMode
This enumeration describes the type of validation test to run on shapes.
The simple tests are used internally before any method call is made to a shape. In this way, we have a certain level of confidence that the operation will succeed. The advanced tests are meant to be performed by users if they get a shape from an external source and consider it suspect.
Items
Simple
  • Summary:The simple tests are designed to be very fast.
Advanced
  • Summary:The advanced tests are designed to be comprehensive with no regard to speed.
thinkgeo.mapsuite.silverlightcore.shapevalidationmode.txt · Last modified: 2017/03/16 21:59 (external edit)
