ConvertToExternalProjection(Double,Double)
ConvertToExternalProjection(BaseShape)
ConvertToExternalProjection(Feature)
ConvertToInternalProjection(Double,Double)
ConvertToInternalProjection(Feature)
ConvertToInternalProjection(RectangleShape)
ConvertToExternalProjectionCore(Double[],Double[])
ConvertToInternalProjectionCore(Double[],Double[])
GetInternalGeographyUnitCore()
This method will reflect whether the projection is opened or closed. It is set in the concrete methods Open and Close, so if you inherit from this class and override OpenCore or CloseCore, you will not need to be concerned with setting this property.
