The abstract class from which area shapes, line shapes, and point shapes inherit from.
CreateShapeFromWellKnownData(String)
CreateShapeFromWellKnownData(Byte[])
TranslateByOffset(BaseShape,Double,Double,GeographyUnit,DistanceUnit)
TranslateByOffset(Feature,Double,Double,GeographyUnit,DistanceUnit)
TranslateByDegree(BaseShape,Double,Double,GeographyUnit,DistanceUnit)
TranslateByDegree(Feature,Double,Double,GeographyUnit,DistanceUnit)
Rotate(BaseShape,PointShape,Single)
Rotate(Feature,PointShape,Single)
If this property returns false and you attempt to call the rotate method, it will throw a NotImplementedException.
