thinkgeo.mapsuite.silverlightcore.projnetprojection
ThinkGeo.MapSuite.SilverlightCore.ProjNetProjection
    • ThinkGeo.MapSuite.SilverlightCore.Projection
      • ThinkGeo.MapSuite.SilverlightCore.ProjNetProjection
ProjNetProjection()
  • This is the default constructor for this class.
  • This conctructor pass nothing. After this cconstructor , you should set the InternalProjectionParametersString property and ExternalProjectionParametersString property before open to use.
ProjNetProjection(String,String)
  • This constructor allows you to pass in Proj4 text parameters for the to and from projection. The parameters typically look like “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs” You should use this constructor when you know the parameters. If you know the SRID directly you can use the other constructor that takes the SRID.
  • internalProjectionParametersString
    • Description:This parameter is the projection parameters describing the data.
  • externalProjectionParametersString
    • Description:This parameter is the projection parameters describing the projection you want to go to.
ProjNetProjection(Int32,Int32)
  • This constructor allows you to pass in Proj4 srid parameters for the to and from projection. The parameters typically look like 4320 stands for “+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs” and 4604 stands for “ +proj=longlat +ellps=clrk80 +towgs84=174,359,365,0,0,0,0 +no_defs”. You should use this constructor when you know the parameters. If you know the SRID directly you can use the other constructor that takes the SRID.
  • internalEpsgSrid
    • Description:This parameter is the projection srid parameter describing the data.
  • externalEpsgSrid
    • Description:This parameter is the projection srid parameter describing the projection you want to go to.
Dispose()
  • This is the dispose method for the class.
  • This dispose releases the handles of the Proj4 library. You should normally use Close instead of dispose unless you really want to never use this instance again. Normally when a layer is finished drawing it will call the Close of the projection class. This allows the object to be serialize but used again in the future. You should only use the Dispose method when you do not want to use this class again.
  • Description:None
Open()
Close()
ConvertToExternalProjection(Double,Double)
  • x
  • y
ConvertToExternalProjection(BaseShape)
ConvertToExternalProjection(Feature)
  • feature
ConvertToInternalProjection(Double,Double)
  • x
  • y
ConvertToInternalProjection(Feature)
  • feature
ConvertToInternalProjection(RectangleShape)
GetInternalGeographyUnit()
GetExternalGeographyUnit()
ConvertToExternalProjectionCore(Double[],Double[])
  • x
    • Type:Double[]
  • y
    • Type:Double[]
ConvertToInternalProjectionCore(Double[],Double[])
  • x
    • Type:Double[]
  • y
    • Type:Double[]
OpenCore()
  • This method open the projection and gets it ready to use.
  • As this is the core version of the Open method it is intended to be overridden in inherited version of the class. When overriding you will be responsible for getting the projection classes state ready for doing projections. In this override we call the Proj4 methods get it ready for projection.
  • Description:None
CloseCore()
  • This method closes the projection and gets it ready to serialization if necessary.
  • As this is the core version of the Close method it is intended to be overridden in inherited version of the class. When overriding you will be responsible freeing any state you have maintained and getting the class ready to serialization if necessary. Note that the object may be opened again so you want to make sure you can open and close the object multiple tiles without any ill effects. In this override we call the Proj4 methods get release the handles and memory.
  • Description:None
0RM=(Feature)
  • feature
0hM=(Feature)
  • feature
GetInternalGeographyUnitCore()
GetExternalGeographyUnitCore()
Gets or sets the Proj4 text parameter for the from projection. This parameter typically look like “+Proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs”.
Gets or sets the Proj4 text parameter for the to projection. This parameter typically look like “+proj=utm +zone=33 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs”.
IsOpen
CanReproject
thinkgeo.mapsuite.silverlightcore.projnetprojection.txt · Last modified: 2017/03/16 21:59 (external edit)
