thinkgeo.mapsuite.silverlightcore.layersdrawingeventargs
ThinkGeo.MapSuite.SilverlightCore.LayersDrawingEventArgs
      • ThinkGeo.MapSuite.SilverlightCore.LayersDrawingEventArgs
LayersDrawingEventArgs()
LayersDrawingEventArgs(IEnumerable<Layer>,RectangleShape,Object)
  • None
  • layers
    • Type:IEnumerable<Layer>
    • Description:This parameter is the layers that will be drawn.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
Cancel
This property gets and sets the value that indicates you want to cancel all of the layers from drawing.
WorldExtent
This property gets and sets the world extent that will be drawn.
NativeImage
This property gets and sets the GeoImage or native image that we are drawing on.
Layers
This property gets and sets the layers you will be drawing.
thinkgeo.mapsuite.silverlightcore.layersdrawingeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
