thinkgeo.mapsuite.silverlightcore.committingtransactioneventargs
ThinkGeo.MapSuite.SilverlightCore.CommittingTransactionEventArgs
      • ThinkGeo.MapSuite.SilverlightCore.CommittingTransactionEventArgs
CommittingTransactionEventArgs(TransactionBuffer)
  • This is the default constructor for the event.
  • None
  • transactionBuffer
    • Description:This parameter represents the transaction buffer that needs to be committed.
CommittingTransactionEventArgs()
  • This is the constructor of the event arguments.
  • None
Cancel
This property allows you to cancel the transaction.
TransactionBuffer
This property returns the transaction buffer that needs to be committed.
thinkgeo.mapsuite.silverlightcore.committingtransactioneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
