thinkgeo.mapsuite.silverlightcore.pointstyle
ThinkGeo.MapSuite.SilverlightCore.PointStyle
    • ThinkGeo.MapSuite.SilverlightCore.Style
      • ThinkGeo.MapSuite.SilverlightCore.PointStyle
PointStyle()
If you use this constructor, you should set the various properties manually. Specifically, you will want to set the PointType, which allows you to choose between bitmap, character and symbol as an option for displaying your points.
PointStyle(GeoImage)
If you use this constructor, the PointStyle will be set to Bitmap.
  • image
    • Type:GeoImage
    • Description:This parameter is the GeoImage of the image you want to use to display the point.
PointStyle(GeoFont,Int32,GeoSolidBrush)
If you use this constructor, the PointStyle will be set to Character.
  • characterFont
    • Type:GeoFont
    • Description:This parameter is the font from which the character will be selected.
  • characterIndex
    • Description:This parameter is the index of the character in the chosen font.
  • characterSolidBrush
    • Description:This parameter is the SolidBrush used to draw the character.
PointStyle(PointSymbolType,GeoSolidBrush,Int32)
If you use this constructor, the PointStyle will be set to Symbol.
  • symbolType
    • Description:This parameter is the type of symbol you want to use, such as a square or a circle.
  • symbolSolidBrush
    • Description:This parameter is the SolidBrush you want to use to fill the inside of the symbol.
  • symbolSize
    • Description:This parameter is the size you want the symbol to be.
PointStyle(PointSymbolType,GeoSolidBrush,GeoPen,Int32)
  • symbolType
  • symbolSolidBrush
  • symbolPen
    • Type:GeoPen
    • Description:This parameter is the Pen used to draw the outline of the symbol.
  • symbolSize
  • features
    • Type:IEnumerable<Feature>
  • shapes
    • Type:IEnumerable<BaseShape>
GetRequiredColumnNames()
  • Type:Collection<String>
  • Description:None
  • features
  • canvas
    • Type:GeoCanvas
  • labelsInThisLayer
  • labelsInAllLayers
GetRequiredColumnNamesCore()
XOffsetInPixel
This property gets and sets the X pixel offset for drawing each feature.
This property allows you to specify an X offset. When combined with a Y offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
YOffsetInPixel
This property gets and sets the Y pixel offset for drawing each feature.
This property allows you to specify a Y offset. When combined with an X offset, it is useful to allow you to achieve effects such as drop shadows, etc. There also may be times when you need to modify the location of feature data so as to better align it with raster satellite data.
  • Type:Single
CustomPointStyles
This property returns a collection of area styles allowing you to stack multiple area styles on top of each other.
Using this collection, you can stack multiple styles on top of each other. When we draw the feature, we will draw them in order that they exist in the collection. You can use these stacks to create drop shadow effects, multiple colored outlines, etc.
PointType
This property gets and sets the type of point you want to draw.
When using the PointStyle you choose between a bitmap, a font or a predefined symbol to represent the point. Each of these options has corresponding properties on the point symbol. If you set the type to character, then you need to set the properties that start with “Character,” such as “CharacterFont.” The same is true for the symbol.
RotationAngle
This property gets and sets the angle of rotation for the drawing of the point.
This property controls the rotation of the bitmap, character or symbol, depending on the PointType.
  • Type:Single
This property gets and sets the image used if the PointType property is Bitmap.
This property is where you can set the image for the points if the PointType is Bitmap. It uses a GeoImage, so you can either reference a file or supply a stream.
ImageScale
This property gets and sets the scale of the image you want to draw.
This property allows you to scale the image up and down depending on how large or small you want it. It can be changed dynamically, so you could change it at every scale level to resize the bitmap based on the current scale. A scale of 1 would be the original size, while a scale of 2 would double the size. A scale of .5 would reduce the size of the image by half, and so on.
CharacterFont
This property gets and sets the font that is used for the character if the PointType is Character.
This property allows you to set the font from which to select a character index if you choose the Character PointType.
CharacterIndex
This property gets and sets the index position of the character you want to use from the font you selected in the CharacterFont property.
You need to specify the index position of the character you want to use from the font you selected. For example, if you choose 1, then we will use the first character in the font you set in the CharacterFont property.
CharacterWpfGeoBrush
This property gets and sets the SolidBrush used to color the font character for the point.
This brush is used to draw the character. It is only used if the PointType is Character. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
SymbolType
This property gets and sets the type of symbol you want to use if the PointType is Symbol.
You can choose between a number of predefined symbols. The symbols are simple geometric objects that are typically used for abstract representations on a map. If there is a specific symbol you need that is not part of our symbol collection, you can submit it to us and we will consider adding it.
SymbolWpfGeoBrush
This property gets and sets the SolidBrush used to color the interior of the Symbol.
This brush is used to draw the interior of the symbol. It is only used if the PointType is Symbol. If you need a brush other than the SolidBrush, you should look in the advanced property of the class.
SymbolPen
This property gets and sets the SolidBrush used to draw the oultine of the Symbol.
This pen is used to draw the outline of the Symbol. By default the pen draws a transparent (invisible) color, which just leaves you with a fill.
SymbolSize
This property gets and sets the size of the symbol if the PointType is Symbol.
The allows you to make the symbol larger and smaller.
  • Type:Single
Advanced
This property gets the advanced properties of the PointStyle.
This allows you to set the advanced properties of the style.
IsActive
RequiredColumnNames
bho=
thinkgeo.mapsuite.silverlightcore.pointstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
