thinkgeo.mapsuite.silverlightcore.pointstyleadvanced
ThinkGeo.MapSuite.SilverlightCore.PointStyleAdvanced
    • ThinkGeo.MapSuite.SilverlightCore.PointStyleAdvanced
PointStyleAdvanced()
  • This is the default constructor for the class.
  • None
CustomBrush
This property allows you to get and set a custom brush.
This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
thinkgeo.mapsuite.silverlightcore.pointstyleadvanced.txt · Last modified: 2017/03/16 21:59 (external edit)
