thinkgeo.mapsuite.silverlightcore.geoimage
ThinkGeo.MapSuite.SilverlightCore.GeoImage
This class represents an image you want to use on the GeoCanvas.
    • ThinkGeo.MapSuite.SilverlightCore.GeoImage
GeoImage()
  • This is the constructor used to create a new GeoImage.
  • You need to set the imageUri if you intend to use this constructor.
GeoImage(Uri)
  • imageUri
    • Type:Uri
GeoImage(Uri,Double,Double)
  • imageUri
    • Type:Uri
  • width
  • height
Dispose()
  • This is the Dispose for the class.
  • This overload will dispose of the stream in the GeoImage and release its resources.
  • Description:None
Width
Height
ImageUri
  • Type:Uri
CanvasImageFormat
This property returns the image format.
  • Type:Guid
SourceStream
  • Type:Stream
thinkgeo.mapsuite.silverlightcore.geoimage.txt · Last modified: 2017/03/16 21:59 (external edit)
