thinkgeo.mapsuite.silverlightcore.drawingrectanglef
ThinkGeo.MapSuite.SilverlightCore.DrawingRectangleF
This structure represents the drawing of a rectangle in screen coordinates.
    • System.ValueType
      • ThinkGeo.MapSuite.SilverlightCore.DrawingRectangleF
DrawingRectangleF(Double,Double,Double,Double)
  • This method represents the constructor that should be used to create the structure.
  • centerX
    • Description:This parameter represents the center horizontal value of the rectangle.
  • centerY
    • Description:This parameter represents the center vertical value of the rectangle.
  • width
    • Description:This parameter represents the width of the rectangle.
  • height
    • Description:This parameter represents the height of the rectangle.
  • This method is an override of the Equals functionality.
  • None
  • This method is an override of the GetHashCode functionality.
  • None
CenterX
CenterY
Width
This parameter returns the width of the rectangle.
Height
This parameter returns the height of the rectangle.
thinkgeo.mapsuite.silverlightcore.drawingrectanglef.txt · Last modified: 2017/03/16 21:59 (external edit)
