thinkgeo.mapsuite.silverlightcore.dbfcolumn
ThinkGeo.MapSuite.SilverlightCore.DbfColumn
This class represents the column information specific to a DBF column.
    • ThinkGeo.MapSuite.SilverlightCore.FeatureSourceColumn
      • ThinkGeo.MapSuite.SilverlightCore.DbfColumn
DbfColumn(String,DbfColumnType,Int32,Int32)
  • This method is the constructor for the DbfColumn.
  • None
  • columnName
    • Description:This parameter represents the name of the column in the DBF.
  • columnType
    • Description:This parameter represents the type of the column in the DBF.
  • length
    • Description:This parameter represents the length of the column in the DBF.
  • decimalLength
    • Description:This parameter represents the number of decimal places the column has, if it is a numeric type.
DbfColumn()
  • None
ColumnName
This property returns the name of the column in the DBF.
ColumnType
This property returns the type of the column in the DBF.
Length
This property returns the length of the column in the DBF.
DecimalLength
This property returns the decimal length of the column in the DBF.
This is the number of decimal places the number represents. This is only applicable if the column type is numeric.
TypeName
MaxLength
thinkgeo.mapsuite.silverlightcore.dbfcolumn.txt · Last modified: 2017/03/16 21:59 (external edit)
