This class represents a style based on class break values.
ClassBreakStyle(String,BreakValueInclusion)
ClassBreakStyle(String,BreakValueInclusion,Collection<ClassBreak>)
This property gets and sets the column name in the FeatureSource where the data will be found for each feature.
You use this property to set the name of the column where the numeric data is stored for your features.
This property gets and sets the value of if the break values are included in the break calculation.
Example: If you have a class break value set to 100 and the break value is included, then 100 is included for this break. If you set the value to excluded, then 100 would match with the break below 100 instead. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
The class breaks determine which style to use, based on the break values. Please see the ClassBreakStyle class remarks for a full description of how the ClassBreakStyle works.
