thinkgeo.mapsuite.silverlightcore.extenthelper
ThinkGeo.MapSuite.SilverlightCore.ExtentHelper
This static class exposes a number of helpful methods when dealing with extents.
    • ThinkGeo.MapSuite.SilverlightCore.ExtentHelper
GetDrawingExtent(RectangleShape,Double,Double)
  • This method returns an adjusted extent based on the ratio of the screen width and height.
  • This function is used because the extent to draw must be the rame ratio as the screen width and height. If they are not, then the image drawn will be stretched or compressed. We always adjust the extent upwards to ensure that no matter how we adjust it, the original extent will fit within the new extent. This ensures that everything you wanted to see in the first extent is visible and maybe a bit more.
  • Description:This method returns an adjusted extent based on the ratio of the screen width and height.
  • worldExtent
    • Description:This parameter is the world extent you want to adjust for drawing.
  • screenWidth
    • Description:This parameter is the width of the screen.
  • screenHeight
    • Description:This parameter is the height of the screen.
CenterAt(RectangleShape,PointShape,Double,Double)
  • This is a static function that allows you to pass in a world rectangle, a world point to center on, and a height and width in screen units. The function will center the rectangle based on the point, then adjust the rectangle's ratio based on the height and width in screen coordinates.
  • None
  • Description:This method returns an adjusted extent centered on a point.
  • worldExtent
    • Description:This parameter is the current extent you want to center.
  • worldPoint
    • Description:This parameter is the world point you want to center on.
  • screenWidth
  • screenHeight
CenterAt(RectangleShape,Feature,Double,Double)
  • None
  • worldExtent
  • centerFeature
  • screenWidth
  • screenHeight
CenterAt(RectangleShape,Double,Double,Double,Double)
  • This method returns an adjusted extent centered on a point.
  • None
  • worldExtent
  • screenX
    • Description:This parameter is the X coordinate on the screen to center on.
  • screenY
    • Description:This parameter is the Y coordinate on the screen to center on.
  • screenWidth
  • screenHeight
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,PointShape,PointShape,Double,Double)
  • This method returns the number of pixels between two world points.
  • None
  • Description:This method returns the number of pixels between two world points.
  • worldExtent
  • worldPoint1
    • Description:This parameter is the first point – the one you want to measure from.
  • worldPoint2
    • Description:This parameter is the second point – the one you want to measure to.
  • screenWidth
  • screenHeight
GetScreenDistanceBetweenTwoWorldPoints(RectangleShape,Feature,Feature,Double,Double)
  • This method returns the number of pixels between two features.
  • None
  • Description:This method returns the number of pixels between two features.
  • worldExtent
  • worldPointFeature1
    • Type:Feature
    • Description:This parameter is the first feature – the one you want to measure from.
  • worldPointFeature2
    • Type:Feature
    • Description:This parameter is the second feature – the one you want to measure to.
  • screenWidth
  • screenHeight
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,Point,Point,Double,Double,GeographyUnit,DistanceUnit)
  • This method returns the distance in world units between two screen points.
  • None
  • Description:This method returns the distance in world units between two screen points.
  • worldExtent
  • screenPoint1
    • Type:Point
    • Description:This is the screen point you want to measure from.
  • screenPoint2
    • Type:Point
    • Description:This is the screen point you want to measure to.
  • screenWidth
  • screenHeight
  • worldExtentUnit
    • Description:This is the geographic unit of the world extent rectangle.
  • distanceUnit
    • Description:This is the geographic unit you want the result to show in.
GetWorldDistanceBetweenTwoScreenPoints(RectangleShape,Double,Double,Double,Double,Double,Double,GeographyUnit,DistanceUnit)
  • worldExtent
  • screenPoint1X
    • Description:This parameter is the X of the point you want to measure from.
  • screenPoint1Y
    • Description:This parameter is the Y of the point you want to measure from.
  • screenPoint2X
    • Description:This parameter is the X of the point you want to measure to.
  • screenPoint2Y
    • Description:This parameter is the Y of the point you want to measure to.
  • screenWidth
  • screenHeight
  • worldExtentUnit
    • Description:This is the geographic unit of the world extent you passed in.
  • distanceUnit
GetScale(RectangleShape,Double,GeographyUnit)
  • screenWidth
GetScale(RectangleShape,Double,GeographyUnit,Single)
  • This method returns the current scale.
  • None
  • Description:This method returns the current scale.
  • worldExtent
    • Description:This parameter is the world extent you want to find the scale for.
  • screenWidth
    • Description:This parameter is the screen width.
  • worldExtentUnit
    • Description:This parameter is the unit of the world extent.
  • dpi
    • Type:Single
GetBoundingBoxOfItems(IEnumerable<BaseShape>)
  • This API gets the BoundingBox of a group of BaseShapes.
  • Description:The BoundingBox that contains all of the shapes you passed in.
  • shapes
    • Type:IEnumerable<BaseShape>
    • Description:The target group of BaseShapes to get the BoundingBox for.
GetBoundingBoxOfItems(IEnumerable<Feature>)
  • This API gets the BoundingBox of a group of Features.
  • Description:The BoundingBox that contains all the features you passed in.
  • features
    • Type:IEnumerable<Feature>
    • Description:The target group of Features to get the BoundingBox for.
ZoomIn(RectangleShape,Int32)
  • This method returns a new extent that is zoomed in by the percentage provided.
  • None
  • Description:This method returns a new extent that is zoomed in by the percentage provided.
  • worldExtent
    • Description:This parameter is the world extent you want to zoom to.
  • percentage
    • Description:This parameter is the percentage by which you want to zoom in.
ZoomIntoCenter(RectangleShape,Int32,PointShape,Double,Double)
  • This method returns an extent that is centered and zoomed in.
  • The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterwards.
  • Description:This method returns an extent that is centered and zoomed in.
  • worldExtent
    • Description:This parameter is the world extent that you want centered and zoomed to.
  • percentage
  • worldPoint
    • Description:This parameter is the world point you want the extent to be centered on.
  • screenWidth
    • Description:This parameter is the width in screen coordinates.
  • screenHeight
    • Description:This parameter is the height in screen coordinates.
ZoomIntoCenter(RectangleShape,Int32,Feature,Double,Double)
  • This method returns an extent that is centered and zoomed.
  • worldExtent
  • percentage
  • centerFeature
    • Type:Feature
    • Description:This parameter is the feature you want the extent to be centered on.
  • screenWidth
  • screenHeight
ZoomIntoCenter(RectangleShape,Int32,Double,Double,Double,Double)
  • worldExtent
    • Description:This parameter is the world extent you want to center and zoom to.
  • percentage
  • screenX
    • Description:This parameter is the screen X you want to center on.
  • screenY
    • Description:This parameter is the screen Y you want to center on.
  • screenWidth
  • screenHeight
ZoomOut(RectangleShape,Int32)
  • This method returns a new extent that is zoomed out by the percentage provided.
  • None
  • Description:This method returns a new extent that is zoomed out by the percentage provided.
  • worldExtent
    • Description:This parameter is the world extent you want to zoom out to.
  • percentage
    • Description:This parameter is the percentage by which you want to zoom out.
ZoomOutToCenter(RectangleShape,Int32,PointShape,Double,Double)
  • This method returns an extent that is centered and zoomed out.
  • Description:This method returns an extent that is centered and zoomed out.
  • worldExtent
    • Description:This parameter is the world extent you want to center and zoom out to.
  • percentage
  • worldPoint
  • screenWidth
  • screenHeight
ZoomOutToCenter(RectangleShape,Int32,Feature,Double,Double)
  • worldExtent
  • percentage
  • centerFeature
    • Type:Feature
  • screenWidth
  • screenHeight
ZoomOutToCenter(RectangleShape,Int32,Double,Double,Double,Double)
  • The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to call GetDrawingExtent afterward.
  • worldExtent
  • percentage
  • screenX
  • screenY
  • screenWidth
  • screenHeight
Pan(RectangleShape,PanDirection,Int32)
  • This method returns a panned extent.
  • None
  • Description:This method returns a panned extent.
  • worldExtent
    • Description:This parameter is the world extent you want to pan.
  • direction
    • Description:This parameter is the direction in which you want to pan.
  • percentage
    • Description:This parameter is the percentage by which you want to pan.
Pan(RectangleShape,Double,Int32)
  • None
  • worldExtent
  • degree
    • Description:This parameter is the degree you want to pan.
  • percentage
ToScreenCoordinate(RectangleShape,Double,Double,Double,Double)
  • This method returns screen coordinates from world coordinates.
  • None
  • Type:Point
  • Description:This method returns screen coordinates from world coordinates.
  • worldExtent
  • worldX
    • Description:This parameter is the world X you want converted to screen points.
  • worldY
    • Description:This parameter is the world Y you want converted to screen points.
  • screenWidth
  • screenHeight
ToScreenCoordinate(RectangleShape,PointShape,Double,Double)
  • None
  • Type:Point
  • worldExtent
  • worldPoint
    • Description:This parameter is the world point you want converted to a screen point.
  • screenWidth
  • screenHeight
ToScreenCoordinate(RectangleShape,Feature,Double,Double)
  • None
  • Type:Point
  • worldExtent
  • worldPointFeature
    • Type:Feature
    • Description:This parameter is the feature you want converted to a screen point.
  • screenWidth
  • screenHeight
ToWorldCoordinate(RectangleShape,Double,Double,Double,Double)
  • This method returns world coordinates from screen coordinates.
  • None
  • Description:This method returns world coordinates from screen coordinates.
  • worldExtent
  • screenX
    • Description:This parameter is the X of the point you want converted to world coordinates.
  • screenY
    • Description:This parameter is the Y of the point you want converted to world coordinates.
  • screenWidth
  • screenHeight
ToWorldCoordinate(RectangleShape,Point,Double,Double)
  • None
  • worldExtent
  • screenPoint
    • Type:Point
    • Description:This parameter is the screen point you want converted to a world point.
  • screenWidth
  • screenHeight
SnapToZoomLevel(RectangleShape,GeographyUnit,Double,Double,ZoomLevelSet)
  • This method returns an extent that is snapped to a zoom level in the provided zoom level set.
  • None
  • Description:This method returns an extent that is snapped to a zoom level in the provided zoom level set.
  • worldExtent
    • Description:This parameter is the world extent you want snapped.
  • worldExtentUnit
    • Description:This parameter is the geographic unit of the world extent parameter.
  • screenWidth
  • screenHeight
    • Description:This parameter is the screen height.
  • zoomLevelSet
    • Description:This parameter is the set of zoom levels you want to snap to.
ZoomToScale(Double,RectangleShape,GeographyUnit,Double,Double)
  • This method returns a extent that has been zoomed into a certain scale.
  • None
  • Description:This method returns a extent that has been zoomed into a certain scale.
  • targetScale
    • Description:This parameter is the scale you want to zoom into.
  • worldExtent
    • Description:This parameter is the world extent you want zoomed into the scale.
  • worldExtentUnit
  • screenWidth
  • screenHeight
ZoomToScale(Double,RectangleShape,GeographyUnit,Double,Double,Point)
  • None
  • targetScale
  • worldExtent
  • worldExtentUnit
  • screenWidth
  • screenHeight
  • offsetScreenPoint
    • Type:Point
    • Description:This parameter is the offsetScreenPoint.
ZoomIntoOffsetPoint(RectangleShape,Double,Double,Point,Int32)
  • This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
  • The resulting rectangle will already be adjusted for the ratio of the screen. You do not need to afterward call GetDrawingExtent.
  • Description:This method returns an extent that is keeping the offsetScreenPoint constant and zoomed.
  • worldExtent
    • Description:This parameter is the world extent that you want centered and zoomed.
  • screenWidth
  • screenHeight
  • offsetScreenPoint
    • Type:Point
    • Description:This parameter is the screen point you want to keep it constant.
  • percentage
    • Description:This parameter is the percentage you want to zoom.
ZoomOutToOffsetPoint(RectangleShape,Double,Double,Point,Int32)
  • worldExtent
  • screenWidth
  • screenHeight
  • offsetScreenPoint
    • Type:Point
  • percentage
thinkgeo.mapsuite.silverlightcore.extenthelper.txt · Last modified: 2017/03/16 21:59 (external edit)
