thinkgeo.mapsuite.silverlightcore.geolineargradientbrush
ThinkGeo.MapSuite.SilverlightCore.GeoLinearGradientBrush
    • ThinkGeo.MapSuite.SilverlightCore.GeoBrush
      • ThinkGeo.MapSuite.SilverlightCore.GeoLinearGradientBrush
GeoLinearGradientBrush(Vertex,Vertex,Collection<GeoGradientStop>)
  • startPoint
  • endPoint
GeoLinearGradientBrush()
  • Create a new instance of the GeoLinearGradientBrush with default settings.
StartPoint
EndPoint
GeoGradientStops
GeoGradientSpreadMethod
GeoMappingMode
Id
  • Type:Int64
Opacity
thinkgeo.mapsuite.silverlightcore.geolineargradientbrush.txt · Last modified: 2017/03/16 21:59 (external edit)
