thinkgeo.mapsuite.silverlightcore.geobrushmappingmode
ThinkGeo.MapSuite.SilverlightCore.GeoBrushMappingMode
Items
Absolute
  • Summary:The coordinate system is not relative to a bounding box. Values are interpreted directly in local space.
RelativeToBoundingBox
  • Summary:The coordinate system is relative to a bounding box: 0 indicates 0 percent of the bounding box, and 1 indicates 100 percent of the bounding box. For example, (0.5, 0.5) describes a point in the middle of the bounding box, and (1, 1) describes a point at the bottom right of the bounding box.
thinkgeo.mapsuite.silverlightcore.geobrushmappingmode.txt · Last modified: 2017/03/16 21:59 (external edit)
