thinkgeo.mapsuite.silverlightcore.linedashstyle
ThinkGeo.MapSuite.SilverlightCore.LineDashStyle
This enumeration specifies the style of dashed lines drawn with a GeoPen object.
Items
Solid
  • Summary:Specifies a solid line.
Custom
  • Summary:Specifies a user-defined custom dash style.
DashDot
  • Summary:Specifies a line consisting of a repeating pattern of dash-dot.
DashDotDot
  • Summary:Specifies a line consisting of a repeating pattern of dash-dot-dot.
Dot
  • Summary:Specifies a line consisting of dots.
Dash
  • Summary:Specifies a line consisting of dashes.
thinkgeo.mapsuite.silverlightcore.linedashstyle.txt · Last modified: 2017/03/16 21:59 (external edit)
