thinkgeo.mapsuite.silverlightcore.labelingcandidate
ThinkGeo.MapSuite.SilverlightCore.LabelingCandidate
This class represents a candidate for labeling.
LabelingCandidate()
  • If you use this constructor, then you should set the applicable properties manually.
LabelingCandidate(String,PolygonShape,PointShape)
  • None
  • originalText
    • Description:This parameter represents the text of the label before it is potentially modified.
  • simplePolygonInScreenCoordinates
    • Description:This parameter is a polygon (in screen coordinates) representing the area to be labeled.
  • centerPointInScreenCoordinates
    • Description:This parameter is the center of the polygon (in screen coordinates) representing the area to be labeled.
LabelingCandidate(String,PolygonShape,PointShape,Collection<LabelInformation>)
  • None
  • originalText
  • labelInformation
    • Type:Collection<LabelInformation>
    • Description:This parameter is the labeling information for this labeling candidate.
OriginalText
This property gets and sets the original text for the label.
ScreenArea
This property gets and sets the screen area that encompasses the label.
CenterPoint
This property gets and sets the center point for the center of the label.
LabelInformation
This property gets and sets the label information for this label.
thinkgeo.mapsuite.silverlightcore.labelingcandidate.txt · Last modified: 2017/03/16 21:59 (external edit)
