map_suite_world_map_kit_wms_server
Map Suite World Map Kit WMS Server
This product has been discontinued! However you can still serve up the World Map Kit by WMS using the Map Suite WMS Server Edition product and a WMS plugin provided with the Map Suite World Map Kit SDK.
If you want to set up your own web map server (WMS) and need a complete package including both server and data, the Map Suite World Map Kit WMS Server is the perfect solution. Designed to be hosted on your own servers, the World Map Kit WMS Server takes all the hassle out of setting up a WMS and includes a full set of detailed map data covering the entire world.
Product Guides
Guides Description
Quick Start Guide This guide helps you get you up to speed with integrating the Map Suite WMS Server Edition into your GIS software.
Installation Guide This guide walks you through installing the Map Suite World Map Kit WMS Server Edition on your system.
Deployment Guide This guide walks you through deploying the Map Suite World Map Kit WMS Server Edition into a production environment.
Frequently Asked Questions
Category Description
General Questions These frequently asked questions cover GIS and WMS Server edition topics that are not categorized in other areas.
Screenshots
Topic Attachment Description
Screenshot Gallery N/A The WMS Server Edition screenshots gallery section showcases a wide range of screenshots covering various GIS features of the WMS Server Edition.
Demos
You can view an interactive sample of Map Suite World Map Kit here.
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_world_map_kit_wms_server.txt · Last modified: 2015/09/18 08:51 by admin
