map_suite_world_map_kit_sdk
Map Suite World Map Kit SDK
The Map Suite World Map Kit SDK is an extension for our Map Suite line of GIS developer controls that includes everything you need to display professional-looking maps of any location on Earth. The kit comes with detailed map data covering the entire world. The included source code allows you to redesign the maps or add your own data easily.
Product Guides
This guide walks you through installing the World Map Kit SDK on your system and creating a simple GIS application.
This guide walks you through using SQLite as a storage format.
This guide walks you through using restoring your PostgreSQL backup file.
Code Samples
All Samples
All samples about Map Suite World Map Kit SDK.
Project Templates
These projects show various study cases based on World Map Kit SDK.
NOTE: We have provided several sample applications with source code to help you learn the different capabilities of Map Suite. Each code sample includes an overview, complete source code online to review and the ability to download the sample and run it yourself.
Demo & Screenshots
To see what the maps look like, check out the online demo at maps.thinkgeo.com.
Frequently Asked Questions
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
map_suite_world_map_kit_sdk.txt · Last modified: 2017/03/16 09:07 by tgwikiupdate
