This class allows you to draw features differently based on regular expression matching.
RegexStyle(String,Collection<RegexItem>,RegexMatching)
This property gets and sets the regular expression matching rule. The rule determines whether we match the entire string or just any portion of it.
This is used to determine how much of a string needs to match a regular expression in order to declare it a match for that expression. Sometimes, you only need one part of the string to match in order for the expression to be considered a match; other times you may want the entire string to match.
This property gets and sets the column name whose value will be tested against the regular expression.
This is the column we use for matching.
This property gets the collection of RegexItems. Each item can have its own regular expression to match.
You will want to add RegexItems to this collection. Each item can have its own style and matching string.
