thinkgeo.mapsuite.silverlightcore.tinygeoprecisionmode
ThinkGeo.MapSuite.SilverlightCore.TinyGeoPrecisionMode
Items
AllowSplitting
  • Summary:Don't allow any splitting. In this case the precision will be low.
PreventSplitting
  • Summary:Allow splitting. In this case the precision will be high and the created TinyGeo file will usually include multi regions internally.
thinkgeo.mapsuite.silverlightcore.tinygeoprecisionmode.txt · Last modified: 2017/03/16 21:59 (external edit)
