CreateTinyGeoFile(String,String,GeographyUnit,ReturningColumnsType)
Static API to create a new TinyGeo file from an existed shape file.
CreateTinyGeoFile(String,String,GeographyUnit,ReturningColumnsType,Double)
CreateTinyGeoFile(String,String,GeographyUnit,IEnumerable<String>)
CreateTinyGeoFile(String,String,GeographyUnit,IEnumerable<String>,Double)
CreateTinyGeoFile(String,String,GeographyUnit,IEnumerable<String>,Double,Encoding)
GetOptimalPrecision(String,GeographyUnit,DistanceUnit,TinyGeoPrecisionMode)
This property returns the path and file of the TinyGeo file you want to use.
When you specify the path and file name it should be in the correct format as such however the file does not need to exists on the file system. This is to allow us to accept streams supplied by the developer at runtime. If you choose to provide a file that exists then we will attempt to use it. If we cannot find it then we will raise the SteamLoading event and allow you to supply the stream. For example you can pass in “C:\NotARealPath\File1.tgeo” which does not exists on the file system. When we raise the event for you to supply a stream we will pass to you the path and file name for you to differentiate the files.
If you choose you can pass in your own stream to represent the file. The stream can come from a variety of places such as isolated storage, a compressed file, and encrypted stream. When the Image is finished with the stream it will dispose of it so be sure to keep this in mind when passing the stream in. If you do not pass in a alternate stream the class will attempt to load the file from the file system using the TinyGeoPathFileName property.
