thinkgeo.mapsuite.silverlightcore.returningcolumnstype
ThinkGeo.MapSuite.SilverlightCore.ReturningColumnsType
This enumeration provides some options when querying a feature.
Three options are provided in the query system that can cover all possible cases. Option 1 is to use the ReturningColumnsType.NoColumns, which will return no columns at all. Option 2 is to use the ReturningColumnsType.AllColumns, which will return all columns. Option 3 is used when you want to return parts of the columns in the feature; in this case you should pass in an (IEnumerable[string] returningColumnNames) instead of using this enumeration directly.
Items
NoColumns
  • Summary:Return no column option.
AllColumns
  • Summary:Return all columns option.
thinkgeo.mapsuite.silverlightcore.returningcolumnstype.txt · Last modified: 2017/03/16 21:59 (external edit)
