thinkgeo.mapsuite.silverlightcore.matrix
ThinkGeo.MapSuite.SilverlightCore.Matrix
This class represents a base Matrix which encapsulate the tile caculation logics.
Matrix()
  • This method is the default protected constructor.
  • If you use this constructor, you have to set the properties correctly before use it.
Matrix(String,Double,Double,RectangleShape,MatrixReferenceCorner)
  • None
  • id
    • Description:This parameter specified the id of the Matrix.
  • cellWidth
    • Description:This parameter specified the cell width(in DecimalDegrees) of the Matrix.
  • cellHeight
    • Description:This parameter specified the cell height(in DecimalDegrees) of the Matrix.
  • boundingBox
    • Description:This parameter specified the boundingBox of the Matrix.
  • referenceCorner
    • Description:This parameter specified the cacluation reference corner of the Matrix.
Matrix(String,Double,Double,PointShape,MatrixReferenceCorner,Int64,Int64)
  • None
  • id
  • cellWidth
  • cellHeight
  • referencePoint
    • Description:This parameter specified the cacluation reference point of the Matrix.
  • referenceCorner
  • rowCount
    • Type:Int64
    • Description:This parameter specified the row count of the Matrix.
  • columnCount
    • Type:Int64
    • Description:This parameter specified the column count of the Matrix.
GetAllCells()
  • This method returns all the cells of the TileMatrix.
  • Type:Collection<Cell>
  • Description:This method returns a collection of TileMatrixCell.
GetCell(Int64,Int64)
  • Get the cell by passing a specified row and column.
  • Type:Cell
  • Description:The returning cell by specified the row and column.
  • row
    • Type:Int64
    • Description:This parameter specifies the row based on 1.
  • column
    • Type:Int64
GetCell(PointShape)
  • Get the cell by passing a specified point shape location.
  • Type:Cell
  • Description:The returning cell by specifing the target point location.
  • intersectingPoint
    • Description:The parameter specified the target point location.
GetRowIndex(PointShape)
  • Get the row index by passing a specified point shape location.
  • Type:Int64
  • Description:The returning row index by specifing the target point location.
  • intersectingPoint
GetColumnIndex(PointShape)
  • Get the column index by passing a specified point shape location.
  • Type:Int64
  • Description:The returning column index by specifing the target point location.
  • intersectingPoint
GetIntersectingCells(RectangleShape)
  • This method returns the intersecting cells of the TileMatrix.
  • Description:This method returns a collection of TileMatrixCell which intersecting with the passed in extent.
  • worldExtent
    • Description:This parameter specifies extent which is used to get the tiles back from.
GetContainedCells(RectangleShape)
  • This method returns the contained cells of the TileMatrix.
  • Description:This method returns a collection of TileMatrixCell which contained in the passed in extent.
  • worldExtent
GetIntersectingRowColumnRange(RectangleShape)
  • This method returns the RowColumnRange of the TileMatrix intersects the passed in extent.
  • Description:This method returns the RowColumnRange intersects the passed in extent.
  • worldExtent
GetContainedRowColumnRange(RectangleShape)
  • This method returns the RowColumnRange of the TileMatrix contained the passed in extent.
  • Description:This method returns the RowColumnRange contained the passed in extent.
  • worldExtent
SetMatrix(String,Double,Double,RectangleShape,MatrixReferenceCorner)
  • This method sets the Matrix system by passing in each variables.
  • Accroding to the these given parameters, the referencePoint, rowCount, columnCount can be caculated.
  • id
    • Description:This parameter specifies the id to set the Matrix.
  • cellWidth
    • Description:This parameter specifies the cell width(in decimalDegrees) to set the Matrix.
  • cellHeight
    • Description:This parameter specifies the cell height(in decimalDegrees) to set the Matrix.
  • boundingBox
    • Description:This parameter specifies the boundingBox to set the Matrix.
  • referenceCorner
    • Description:This parameter specifies the reference corner to set the Matrix.
SetMatrix(String,Double,Double,PointShape,MatrixReferenceCorner,Int64,Int64)
  • None
  • id
  • cellWidth
  • cellHeight
  • referencePoint
    • Description:This parameter specifies the reference Point to set the Matrix.
  • referenceCorner
  • rowCount
    • Type:Int64
    • Description:This parameter specifies the row count to set the Matrix.
  • columnCount
    • Type:Int64
    • Description:This parameter specifies the column count to set the Matrix.
SetMatrix(Double,Double)
  • This method sets the Matrix system by passing the cellWidth and cellHeight.
  • None
  • cellWidth
  • cellHeight
CellWidth
This property gets the cell width of the Matrix.
CellHeight
This property gets the cell height of the Matrix.
BoundingBox
This property gets or sets the BouningBox of the Matrix.
The bounding box of the Matrix is related with the referencePoint, cellWidth, cellHeight and the rowCount and columnCount.
RowCount
This property gets the row count of the Matrix.
  • Type:Int64
ColumnCount
This property gets the column count of the Matrix.
  • Type:Int64
Id
This property gets or sets the id of the Matrix.
thinkgeo.mapsuite.silverlightcore.matrix.txt · Last modified: 2017/03/16 21:59 (external edit)
