thinkgeo.mapsuite.silverlightcore.geodashcap
ThinkGeo.MapSuite.SilverlightCore.GeoDashCap
Items
Flat
  • Summary:Specifies a square cap that squares off both ends of each dash.
Square
  • Summary:Specifies a circular cap that rounds off both ends of each dash.
Round
Triangle
  • Summary:Specifies a triangular cap that points both ends of each dash.
thinkgeo.mapsuite.silverlightcore.geodashcap.txt · Last modified: 2017/03/16 21:59 (external edit)
