map_suite_predefined_styles
Map Suite Predefined Style Guide
Overview
MapSuite contains many predefined styles, including the WorldMapKit Predifined Styles outlined below.
Code
This code snippet retrieves all of the AreaStyles returned by the methods in the WorldMapKitAreaStyles class using Reflection, and saves them as images.
          MethodInfo[] methodInfos = typeof(WorldMapKitAreaStyles).GetMethods(BindingFlags.Public | BindingFlags.Static);
          PropertyInfo[] propertyInfos;
          propertyInfos = typeof(WorldMapKitAreaStyles).GetProperties(BindingFlags.Public |
          AreaStyle areaStyle;
          foreach (MethodInfo methodInfo in methodInfos)
              ParameterInfo[] parameterInfos = methodInfo.GetParameters();
              if (parameterInfos.Length > 1)
                  int parmLength = parameterInfos.Length;
              List<object> parmList = new List<object>();
              foreach (ParameterInfo parameterInfo in parameterInfos)
                  if (parameterInfo.ParameterType == typeof(Single) || parameterInfo.ParameterType == typeof(int) || parameterInfo.ParameterType == typeof(float))
                      parmList.Add(25);
                  else if (parameterInfo.ParameterType == typeof(String))
                      parmList.Add("Test");
              object[] parms = new object[] { };
              if (parmList.Count > 0)
                  parms = parmList.ToArray();
              areaStyle = (AreaStyle)methodInfo.Invoke(null, parms);
              Bitmap bitmap = new Bitmap(128, 128);
              GdiPlusGeoCanvas gdiPlusGeoCanvas = new GdiPlusGeoCanvas();
              gdiPlusGeoCanvas.BeginDrawing(bitmap, new RectangleShape(-180, 90, 180, -90), GeographyUnit.DecimalDegree);
              areaStyle.DrawSample(gdiPlusGeoCanvas);
              gdiPlusGeoCanvas.EndDrawing();
              bitmap.Save(@"c:\temp\AreaStyles\" + methodInfo.Name + ".png", ImageFormat.Png);
WorldMapKitLineStyles
The previous code can modified to produce these images, by changing WorldMapKitAreaStyles to WorldMapKitLineStyles, and AreaStyle to LineStyle.
WorldMapKitTextStyles
And by changing WorldMapKitAreaStyles to WorldMapKitTextStyles and AreaStyle to TextStyle, you can produce the images below.
PointStyle
WellPointStyle
Map Suite integrates 186 well points styles in the component. Here the following code will print out each of those style to a standalone bitmap.
  for (int i = 1; i <= 186; i++)
              WellPointStyle pointStyle = new WellPointStyle(i, GeoBrushes.Black, GeoPens.Black, 30);
              pointStyle.DrawSample(gdiPlusGeoCanvas);
              bitmap.Save(@"C:\WellStyles\Number_" + i.ToString() + ".png", ImageFormat.Png);
Here are the icons generated from the code above.
map_suite_predefined_styles.txt · Last modified: 2016/11/16 23:31 by tomtaylor
