thinkgeo.mapsuite.formsedition
ThinkGeo.MapSuite.FormsEdition
<!– NamespacePage –> <!– MapSuiteFormsEdition –>
Classes
Name Summary
AdornmentOverlay
BingMapsOverlay This class represents an overlay that requesting from Bing Maps Imagery Service.
CenterCoordinateMapTool Represents the coordinates of the map center, display in the lower right corner of the map.
CurrentExtentChangedMapViewEventArgs Use to send data when map's extent is changed.
CurrentExtentChangingMapViewEventArgs Use to send data when map's extent is changing.
CurrentScaleChangedMapViewEventArgs Use to send data when map's current scale is changed.
CurrentScaleChangingMapViewEventArgs Use to send data when map's current scale is changing.
EditInteractiveOverlay This class inherits from InterativeOverlay abstract class. This specified overlay describle the EditShape interative process with MapControl using Mouse or Keyborad.
GoogleMapsOverlay This class represents the GoogleMapsOverlay which requests images from Google's image server by its StaticAPI.
GpsMarker
InteractiveOverlay This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
LayerOverlay This class represents a group of layers; each layer can be of any layer type.
MapTool This class represents the base class of map tools.
MapTool‹T› This class represents the base class of map controls.
MapTools Contains the different map tools as properties and acts as an entrance for setting these map controls.
MapView This class represents the map control.
Marker Represents a marker control on the map.
MarkerOverlay This class represents an overlay which maintaining markers.
MouseMovedTrackInteractiveOverlayEventArgs
OpenStreetMapOverlay This class represents an overlay that requesting images from OpenStreet Map Service.
Overlay This class is the base class of all overlays in this overlay system.
Overlay‹T› This class is the base class of all overlays in this overlay system.
Popup This class represents a popup control for placing on the map.
PopupOverlay This class represents an overlay to place popups on the map.
TileOverlay
TileOverlay‹T›
TouchMapViewEventArgs This class represents touch MapView EventArgs.
TrackEndedTrackInteractiveOverlayEventArgs This is the default constructor of this parameter.
TrackEndingTrackInteractiveOverlayEventArgs Provides data for the TrackEnding. event.
TrackInteractiveOverlay This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
TrackStartedTrackInteractiveOverlayEventArgs Provides data for the TrackStarted. event.
TrackStartingTrackInteractiveOverlayEventArgs Provides data for the TrackStarting. event.
VertexAddedTrackInteractiveOverlayEventArgs Provides data for the VertexAdded. event.
VertexAddingTrackInteractiveOverlayEventArgs Provides data for the VertexAdding. event.
WmsOverlay Represents an overlay object that gets map images from the WMS server you specify.
WorldMapKitOverlay This class represents an WmsOverlay which has MapSuite world map kit server integrated.
ZoomMapTool Represents the zooming panel in the upper left corner of the map.
Structures
Name Summary
Enumerations
Name Summary
TileType
TrackMode Enum TrackMode
Interfaces
Name Summary
<!– MapSuiteFormsEdition –> Note: * – not public released, might be removed in the next release. MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
thinkgeo.mapsuite.formsedition.txt · Last modified: 2017/03/16 21:59 (external edit)
