<!– Class –>
GpsMarker |
MemberwiseClone | Object | ||
OnClick | EventArgs | Marker | Handles the event. |
Adapter | MapElementAdapter | Marker(overriden) | Gets the adapter. |
HaloRadiusInMeter | Single | ||
ImageSource | String | Marker(overriden) | Gets or sets the image source. |
Position | PointShape | Marker(overriden) | World Position of marker. It's a wrapper of the PositionProperty. |
XOffset | Int32 | Marker(overriden) | Gets or sets the x offset of marker image. |
YOffset | Int32 | Marker(overriden) | Gets or sets the y offset of marker image. |
Handles the event.
| e | EventArgs<!– System.EventArgs –> | The instance containing the event data. |
<!– ThinkGeo.MapSuite.FormsEdition.Marker –> Go Back
Gets the adapter.
| MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> |
<!– ThinkGeo.MapSuite.FormsEdition.Marker(overriden) –> Go Back
<!– ThinkGeo.MapSuite.FormsEdition.GpsMarker –> Go Back
| PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
Occurs when click.
| Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
