thinkgeo.mapsuite.portablecore.zoomlevelset
ThinkGeo.MapSuite.Core.ZoomLevelSet
ZoomLevelSet()
  • This is the default constructor.
  • This constructor is where we set the default scales for each ZoomLevel. If you inherit from this class to create your own custom ZoomSet, then you should not call the base constructor if you want to supply your own custom ZoomLevels.
GetZoomLevel(RectangleShape,Double,GeographyUnit)
  • This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
  • Type:ZoomLevel
  • Description:This method returns the active ZoomLevel based on an extent, a map unit and a screen width.
  • extent
  • screenWidth
    • Description:This parameter is the width of the map in pixels.
  • mapUnit
    • Description:This parameter is the unit of the map.
GetZoomLevel(RectangleShape,Double,GeographyUnit,Single)
  • Type:ZoomLevel
  • extent
  • screenWidth
  • mapUnit
  • dpi
    • Type:Single
    • Description:This parameter is the dpi of the extent.
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit,Single)
  • This method returns the active ZoomLevel based on an extent, a map unit and a canvas width.
  • Type:ZoomLevel
  • Description:This method returns the active ZoomLevel based on an extent, map unit and a canvas width.
  • extent
  • screenWidth
    • Description:This parameter is the width of the canvas in pixels.
  • mapUnit
  • dpi
    • Type:Single
GetZoomLevelForDrawing(RectangleShape,Double,GeographyUnit)
  • Type:ZoomLevel
  • extent
  • screenWidth
  • mapUnit
GetZoomLevels()
  • This method return all of the zoomLevels in the zoomLevelSet.
  • None.
  • Type:Collection<ZoomLevel>
  • Description:This method return all of the zoomlevels in the zoomLevelSet.
GetLowerZoomLevelScale(Double,ZoomLevelSet)
  • ZoomToScale in, the result is less than input
  • currentScale
GetHigherZoomLevelScale(Double,ZoomLevelSet)
  • ZoomToScale out, the result is greater than input
  • currentScale
GetSnappedZoomLevel(Double)
  • scale
  • This property gets and sets the name for the ZoomSet.
  • The name is user defined. It is useful to set, as it may be used for higher level components such as legends, etc.
CustomZoomLevels
  • This property gets the custom zoom levels from the zoomLevelSet.
  • None
ZoomLevel01
  • This property gets the ZoomLevel for Level01.
  • None
ZoomLevel02
  • This property gets the ZoomLevel for Level02.
  • None
ZoomLevel03
  • This property gets the ZoomLevel for Level03.
  • None
ZoomLevel04
  • This property gets the ZoomLevel for Level04.
  • None
ZoomLevel05
  • This property gets the ZoomLevel for Level05.
  • None
ZoomLevel06
  • This property gets the ZoomLevel for Level06.
  • None
ZoomLevel07
  • This property gets the ZoomLevel for Level07.
  • None
ZoomLevel08
  • This property gets the ZoomLevel for Level08.
  • None
ZoomLevel09
  • This property gets the ZoomLevel for Level09.
  • None
ZoomLevel10
  • This property gets the ZoomLevel for Level10.
  • None
ZoomLevel11
  • This property gets the ZoomLevel for Level11.
  • None
ZoomLevel12
  • This property gets the ZoomLevel for Level12.
  • None
ZoomLevel13
  • This property gets the ZoomLevel for Level13.
  • None
ZoomLevel14
  • This property gets the ZoomLevel for Level14.
  • None
ZoomLevel15
  • This property gets the ZoomLevel for Level15.
  • None
ZoomLevel16
  • This property gets the ZoomLevel for Level16.
  • None
ZoomLevel17
  • This property gets the ZoomLevel for Level17.
  • None
ZoomLevel18
  • This property gets the ZoomLevel for Level18.
  • None
ZoomLevel19
  • This property gets the ZoomLevel for Level19.
  • None
ZoomLevel20
  • This property gets the ZoomLevel for Level20.
  • None
thinkgeo.mapsuite.portablecore.zoomlevelset.txt · Last modified: 2017/03/16 21:59 (external edit)
