thinkgeo.mapsuite.androidedition.trackinteractiveoverlay
ThinkGeo.MapSuite.AndroidEdition.TrackInteractiveOverlay
This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
    • ThinkGeo.MapSuite.AndroidEdition.Overlay
      • ThinkGeo.MapSuite.AndroidEdition.InteractiveOverlay
        • ThinkGeo.MapSuite.AndroidEdition.TrackInteractiveOverlay
TrackInteractiveOverlay()
  • Default constructor of the class. If you use this constructor, please set the properties correctly or it will use their default values.
GetTrackingShape()
  • This method gets the current Tracking shape.
  • This method is the concrete wrapper for the abstract method GetTrackingShapeCore. This method draws the representation of the overlay based on the extent you provided.
  • Type:BaseShape
  • Description:Returns a shape represents the current status of tracking shape.
TouchUp(InteractionArguments)
TouchDown(InteractionArguments)
TouchMove(InteractionArguments)
TouchPointerDown(InteractionArguments)
SingleTap(InteractionArguments)
DoubleTap(InteractionArguments)
LongPress(InteractionArguments)
Refresh(IEnumerable<RectangleShape>)
Refresh(TimeSpan)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,RequestDrawingBufferTimeType)
  • bufferTime
    • Type:TimeSpan
Refresh(TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(RectangleShape,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
  • bufferTime
    • Type:TimeSpan
Refresh(IEnumerable<RectangleShape>,TimeSpan,BufferTimeType)
  • bufferTime
    • Type:TimeSpan
GetBoundingBox()
Initialize(MapArguments)
Refresh()
Refresh(RectangleShape)
Draw(MapArguments,OverlayRefreshType)
PostTransform(TransformArguments,MapArguments)
Close()
Open()
Dispose()
EndTracking()
  • This method ends the tracking shape by initialize some variables.
TouchDownCore(InteractionArguments)
  • This overrides the MouseDown logic in its base class InterativeOverlay.
  • interactionArguments
TouchMoveCore(InteractionArguments)
  • This overrides the MouseMove logic in its base class InterativeOverlay.
TouchUpCore(InteractionArguments)
  • This overrides the MouseUp logic in its base class InterativeOverlay.
SingleTapCore(InteractionArguments)
  • This overrides the MouseClick logic in its base class.
LongPressCore(InteractionArguments)
  • This overrides the MouseDoubleClick logic in its base class InterativeOverlay.
GetTrackingShapeCore()
  • This is the Core method of GetTrackingShape.You could overrides this method to have your own logic. This method gets the current Tracking shape.
  • Type:BaseShape
OnTrackEnded(TrackEndedTrackInteractiveOverlayEventArgs)
  • This event will be fired after the end of Tracking a shape.
OnTrackEnding(TrackEndingTrackInteractiveOverlayEventArgs)
  • This event will be fired before the end of Tracking a shape.
OnTrackStarting(TrackStartingTrackInteractiveOverlayEventArgs)
  • This event will be fired before the start of Tracking a shape.
OnTrackStarted(TrackStartedTrackInteractiveOverlayEventArgs)
  • This event will be fired after the start of Tracking a shape.
OnVertexAdding(VertexAddingTrackInteractiveOverlayEventArgs)
  • This event will be fired before adding a vertex to the Tracking shape.
OnVertexAdded(VertexAddedTrackInteractiveOverlayEventArgs)
  • This event will be fired after adding a vertex to the Tracking shape.
OnMouseMoved(MouseMovedTrackInteractiveOverlayEventArgs)
  • This event will be fired when mouse moved a vertex to the Tracking shape.
DrawCore(MapArguments,OverlayRefreshType)
Dispose(Boolean)
  • disposing
InitializeCore(MapArguments)
TouchPointerDownCore(InteractionArguments)
DoubleTapCore(InteractionArguments)
PostTransformCore(TransformArguments,MapArguments)
GetBoundingBoxCore()
RefreshCore()
RefreshCore(RectangleShape)
CloseCore()
OpenCore()
  • exception
    • Type:Exception
  • ex
    • Type:Exception
OnDrawingException(DrawingExceptionOverlayEventArgs)
OnDrawnException(DrawnExceptionOverlayEventArgs)
IsEmpty
  • This property override the logic in its base class by watching the feature count in trackShapeLayer. If it is empty ,we can skip drawing it for better performance.
TrackShapeLayer
  • This property gets the TrackShape layers which holds the track shapes.
VertexCountInQuarter
Bitmap
  • Type:Bitmap
TrackMode
  • Gets a mode of TrackOverlay.
  • The default mode is TrackMode.None which means you cannot draw or edit features at client. By setting the mode to TrackMode.Point, TrackMode.Line, TrackMode.Polygon etc., you could add point, line or polygon to the FeatureOverlay. Setting the mode to TrackMode.Edit, you could edit the shapes at the client side.
InteractiveView
AutoRefreshInterval
  • Type:TimeSpan
DrawingExceptionMode
IsVisible
Attribution
OverlayView
DrawingQuality
Opacity
MapArguments
CanRefreshRegion
Vertices
  • This property gets the vertices to make up the track shape. This is a protected property which probablly need to be used in its sub classes.
IsInTracking
  • This property gets or sets to sign that if there is any shape being tracking.
TrackEnded
  • This event will be fired after the end of tracking shape.
Event Arguments:TrackEndedTrackInteractiveOverlayEventArgs
TrackEnding
  • This event will be fired before the end of tracking shape.
Event Arguments:TrackEndingTrackInteractiveOverlayEventArgs
TrackStarted
  • This event will be fired after the start of tracking shape.
Event Arguments:TrackStartedTrackInteractiveOverlayEventArgs
TrackStarting
  • This event will be fired before the start of tracking shape.
Event Arguments:TrackStartingTrackInteractiveOverlayEventArgs
VertexAdded
  • This event will be fired after a vertex added to the tracking shape.
Event Arguments:VertexAddedTrackInteractiveOverlayEventArgs
VertexAdding
  • This event will be fired before a vertex added to the tracking shape.
Event Arguments:VertexAddingTrackInteractiveOverlayEventArgs
MouseMoved
  • This event will be fired when mouse moved on the vertex of tracking shape.
Event Arguments:MouseMovedTrackInteractiveOverlayEventArgs
DrawingException
Event Arguments:DrawingExceptionOverlayEventArgs
DrawnException
Event Arguments:DrawnExceptionOverlayEventArgs
thinkgeo.mapsuite.androidedition.trackinteractiveoverlay.txt · Last modified: 2017/03/16 21:59 (external edit)
