thinkgeo.mapsuite.androidedition.interactionarguments
ThinkGeo.MapSuite.AndroidEdition.InteractionArguments
This class encapsulates the information and simple method for interative actions.
    • ThinkGeo.MapSuite.AndroidEdition.InteractionArguments
InteractionArguments()
  • Initializes a new instance of the class.
ScreenPointers
  • Gets the screen pointers.
  • Type:Collection<PointF>
MotionEventActions
  • Gets or sets the motion event actions.
  • Type:MotionEventActions
CurrentExtent
  • Gets or sets the current extent.
ScreenX
  • Gets or sets the screen x.
  • Type:Single
ScreenY
  • Gets or sets the screen y.
  • Type:Single
ZoomLevelSet
  • Gets or sets the ZoomLevelSet used in the Map Control.
MapWidth
  • Gets or sets the width of the map.
MapHeight
  • Gets or sets the height of the map.
Scale
  • Gets or sets the scale.
Resolution
  • Gets or sets the resolution.
WorldX
  • Gets or sets the world x.
WorldY
  • Gets or sets the world y.
SearchingTolerance
  • Gets or sets the searching tolerance.
thinkgeo.mapsuite.androidedition.interactionarguments.txt · Last modified: 2017/03/16 21:59 (external edit)
