thinkgeo.mapsuite.androidedition.trackendingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.TrackEndingTrackInteractiveOverlayEventArgs
Provides data for the TrackEnding. event.
      • ThinkGeo.MapSuite.AndroidEdition.TrackEndingTrackInteractiveOverlayEventArgs
TrackEndingTrackInteractiveOverlayEventArgs()
TrackEndingTrackInteractiveOverlayEventArgs(BaseShape,Boolean)
  • shape
    • Type:BaseShape
    • Description:This parameter specified the shape to be tracking out.
  • cancel
TrackShape
  • This property gets or sets the shape to be tracking out.
Cancel
  • This property gets or sets the action to be canceled or not.
thinkgeo.mapsuite.androidedition.trackendingtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
