thinkgeo.mapsuite.androidedition.vertexaddedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.VertexAddedTrackInteractiveOverlayEventArgs
Provides data for the VertexAdded. event.
      • ThinkGeo.MapSuite.AndroidEdition.VertexAddedTrackInteractiveOverlayEventArgs
VertexAddedTrackInteractiveOverlayEventArgs()
VertexAddedTrackInteractiveOverlayEventArgs(Vertex,Feature)
  • addedVertex
    • Type:Vertex
    • Description:This parameter specified the vertex is added.
  • affectedFeature
    • Type:Feature
    • Description:This parameter specified the feature to be used to add vertex on when tracking shape.
AddedVertex
  • This property gets or sets the vertex added.
AffectedFeature
  • This property gets or sets the Feature with vertex added.
thinkgeo.mapsuite.androidedition.vertexaddedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
