thinkgeo.mapsuite.androidedition.trackendedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.AndroidEdition.TrackEndedTrackInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.AndroidEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs()
TrackEndedTrackInteractiveOverlayEventArgs(BaseShape)
  • trackShape
    • Type:BaseShape
    • Description:This parameter specified the tracked shape.
TrackShape
  • This property gets or sets the tracked shape.
Cancel
  • This property gets or sets the action to be canceled or not. This property has no use any more, please use the it in the TrackInteractiveOverlay.TrackEnding event.
thinkgeo.mapsuite.androidedition.trackendedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
