thinkgeo.mapsuite.androidedition.interactiveresult
ThinkGeo.MapSuite.AndroidEdition.InteractiveResult
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
    • ThinkGeo.MapSuite.AndroidEdition.InteractiveResult
InteractiveResult()
  • Constructor of InteractiveResult class.
InteractiveResult(InteractiveOverlayDrawType,ProcessOtherOverlaysMode)
  • interactiveOverlayDrawType
  • processOtherOverlays
TransformInfo
DrawThisOverlay
  • Gets or sets the DrawThisOverlay type to indicicate to draw this overlay or not.
  • Gets or sets the DrawThisOverlay type to indicicate how to process other overlays.
NewCurrentExtent
  • Gets or sets the new current extent if the interative action affect the extent.
thinkgeo.mapsuite.androidedition.interactiveresult.txt · Last modified: 2017/03/16 21:59 (external edit)
