<!– Class –> This class represents a popup control for placing on the map.
*System.Object Xamarin.Forms.BindableObject *Xamarin.Forms.Element Xamarin.Forms.VisualElement *Xamarin.Forms.View Xamarin.Forms.Layout *Xamarin.Forms.ContentView ThinkGeo.MapSuite.FormsEdition.Popup
Popup | Initializes a new instance of the class. |
BatchBegin | VisualElement | ||
BatchCommit | VisualElement | ||
ClearValue | BindableProperty | BindableObject | |
ClearValue | BindablePropertyKey | BindableObject | |
Focus | VisualElement | ||
ForceLayout | Layout | ||
GetSizeRequest | Double, Double | VisualElement(overriden) | |
GetValue | BindableProperty | BindableObject | |
Layout | Rectangle | VisualElement | |
LowerChild | View | Layout | |
RaiseChild | View | Layout | |
RemoveBinding | BindableProperty | BindableObject | |
RemoveDynamicResource | BindableProperty | Element | |
SetBinding | BindableProperty, BindingBase | BindableObject | |
SetDynamicResource | BindableProperty, String | Element | |
SetValue | BindableProperty, Object | BindableObject | |
SetValue | BindablePropertyKey, Object | BindableObject | |
ToString | Object | ||
Unfocus | VisualElement |
ApplyBindings | Object | BindableObject | |
CreateAdapter | Creates the adapter. | ||
CreateAdapterCore | Creates the adapter core. | ||
InvalidateLayout | Layout | ||
InvalidateMeasure | VisualElement | ||
LayoutChildren | Double, Double, Double, Double | Layout(overriden) | Layouts the children. |
MemberwiseClone | Object | ||
OnBindingContextChanged | BindableObject(overriden) | ||
OnChildAdded | Element | Element | |
OnChildMeasureInvalidated | Object, EventArgs | Layout | |
OnChildMeasureInvalidated | Layout | ||
OnChildRemoved | Element | Element | |
OnChildrenReordered | VisualElement | ||
OnParentSet | Element(overriden) | ||
OnPropertyChanged | String | BindableObject | |
OnPropertyChanging | String | BindableObject | |
OnSizeAllocated | Double, Double | VisualElement(overriden) | |
OnSizeRequest | Double, Double | VisualElement(overriden) | Called when request. |
ShouldInvalidateOnChildAdded | View | Layout | |
ShouldInvalidateOnChildRemoved | View | Layout | |
SizeAllocated | Double, Double | VisualElement | |
UnapplyBindings | BindableObject | ||
UpdateChildrenLayout | Layout |
Adapter | MapElementAdapter | Gets the adapter. | |
AnchorX | Double | VisualElement | |
AnchorY | Double | VisualElement | |
BackgroundColor | Color | VisualElement | |
Behaviors | IList<Behavior> | VisualElement | |
BindingContext | Object | BindableObject | |
Bounds | Rectangle | VisualElement | |
ClassId | String | Element | |
Content | View | ContentView | Gets or sets the content. |
Content | String | Gets or sets the content. | |
GestureRecognizers | IList<IGestureRecognizer> | View | |
Height | Double | VisualElement | |
HeightRequest | Double | VisualElement | |
HorizontalOptions | LayoutOptions | View | |
Id | Guid | Element | |
InputTransparent | Boolean | VisualElement | |
IsClippedToBounds | Boolean | Layout | |
IsEnabled | Boolean | VisualElement | |
IsFocused | Boolean | VisualElement | |
IsVisible | Boolean | VisualElement | |
MinimumHeightRequest | Double | VisualElement | |
MinimumWidthRequest | Double | VisualElement | |
Navigation | INavigation | VisualElement | |
Opacity | Double | VisualElement | |
Padding | Thickness | Layout | |
Parent | Element | Element | |
ParentView | VisualElement | Element | |
Position | PointShape | Gets and sets the position of the popup. | |
Resources | ResourceDictionary | VisualElement | |
Rotation | Double | VisualElement | |
RotationX | Double | VisualElement | |
RotationY | Double | VisualElement | |
Scale | Double | VisualElement | |
Style | Style | VisualElement | |
StyleId | String | Element | |
TranslationX | Double | VisualElement | |
TranslationY | Double | VisualElement | |
Triggers | IList<TriggerBase> | VisualElement | |
VerticalOptions | LayoutOptions | View | |
Width | Double | VisualElement | |
XOffset | Int32 | Gets or sets the x offset. | |
YOffset | Int32 | Gets or sets the y offset. |
BindingContextChanged | EventArgs | BindableObject | |
ChildAdded | ElementEventArgs | Element | |
ChildRemoved | ElementEventArgs | Element | |
ChildrenReordered | EventArgs | VisualElement | |
DescendantAdded | ElementEventArgs | Element | |
DescendantRemoved | ElementEventArgs | Element | |
Focused | FocusEventArgs | VisualElement | |
LayoutChanged | EventArgs | Layout | |
MeasureInvalidated | EventArgs | VisualElement | |
PropertyChanged | PropertyChangedEventArgs | BindableObject | |
PropertyChanging | PropertyChangingEventArgs | BindableObject | |
SizeChanged | EventArgs | VisualElement | |
Unfocused | FocusEventArgs | VisualElement |
Name | Type | Description |
Return Type | Description |
Void<!– System.Void –> |
<!– Xamarin.Forms.VisualElement –> Go Back
property | BindableProperty<!– Xamarin.Forms.BindableProperty –> |
<!– Xamarin.Forms.BindableObject –> Go Back
propertyKey | BindablePropertyKey<!– Xamarin.Forms.BindablePropertyKey –> |
<!– Xamarin.Forms.Layout –> Go Back
Int32<!– System.Int32 –> |
SizeRequest<!– Xamarin.Forms.SizeRequest –> |
widthConstraint | Double<!– System.Double –> | |
heightConstraint | Double<!– System.Double –> |
<!– Xamarin.Forms.VisualElement(overriden) –> Go Back
Type<!– System.Type –> |
bounds | Rectangle<!– Xamarin.Forms.Rectangle –> |
view | View<!– Xamarin.Forms.View –> |
<!– Xamarin.Forms.Element –> Go Back
targetProperty | BindableProperty<!– Xamarin.Forms.BindableProperty –> | |
binding | BindingBase<!– Xamarin.Forms.BindingBase –> |
property | BindableProperty<!– Xamarin.Forms.BindableProperty –> | |
key | String<!– System.String –> |
value | Object<!– System.Object –> |
propertyKey | BindablePropertyKey<!– Xamarin.Forms.BindablePropertyKey –> | |
oldContext | Object<!– System.Object –> |
MapElementAdapter<!– ThinkGeo.MapSuite.FormsEdition.Adapters.MapElementAdapter –> | MapElementAdapter. |
<!– ThinkGeo.MapSuite.FormsEdition.Popup –> Go Back
x | Double<!– System.Double –> | The x. |
y | Double<!– System.Double –> | The y. |
width | Double<!– System.Double –> | The width. |
height | Double<!– System.Double –> | The height. |
<!– Xamarin.Forms.Layout(overriden) –> Go Back
<!– Xamarin.Forms.BindableObject(overriden) –> Go Back
child | Element<!– Xamarin.Forms.Element –> |
sender | Object<!– System.Object –> | |
e | EventArgs<!– System.EventArgs –> |
<!– Xamarin.Forms.Element(overriden) –> Go Back
propertyName | String<!– System.String –> |
width | Double<!– System.Double –> | |
SizeRequest<!– Xamarin.Forms.SizeRequest –> | SizeRequest. |
widthConstraint | Double<!– System.Double –> | The width constraint. |
heightConstraint | Double<!– System.Double –> | The height constraint. |
child | View<!– Xamarin.Forms.View –> |
Gets the adapter.
Return Type |
Return Type |
Return Type |
Return Type |
Color<!– Xamarin.Forms.Color –> |
Return Type |
IList<Behavior><!– System.Collections.Generic.IList{Xamarin.Forms.Behavior} –> |
Return Type |
Return Type |
Return Type |
Return Type |
<!– Xamarin.Forms.ContentView –> Go Back
Return Type |
Return Type |
IList<IGestureRecognizer><!– System.Collections.Generic.IList{Xamarin.Forms.IGestureRecognizer} –> |
<!– Xamarin.Forms.View –> Go Back
Return Type |
Return Type |
Return Type |
LayoutOptions<!– Xamarin.Forms.LayoutOptions –> |
Return Type |
Guid<!– System.Guid –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
INavigation<!– Xamarin.Forms.INavigation –> |
Return Type |
Return Type |
Thickness<!– Xamarin.Forms.Thickness –> |
Return Type |
Return Type |
VisualElement<!– Xamarin.Forms.VisualElement –> |
Return Type |
PointShape<!– ThinkGeo.MapSuite.Core.PointShape –> |
Return Type |
ResourceDictionary<!– Xamarin.Forms.ResourceDictionary –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Style<!– Xamarin.Forms.Style –> |
Return Type |
Return Type |
Return Type |
Return Type |
IList<TriggerBase><!– System.Collections.Generic.IList{Xamarin.Forms.TriggerBase} –> |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Return Type |
Event Arguments |
Event Arguments |
ElementEventArgs<!– Xamarin.Forms.ElementEventArgs –> |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
Event Arguments |
FocusEventArgs<!– Xamarin.Forms.FocusEventArgs –> |
Event Arguments |
Event Arguments |
Event Arguments |
PropertyChangedEventArgs<!– System.ComponentModel.PropertyChangedEventArgs –> |
Event Arguments |
PropertyChangingEventArgs<!– Xamarin.Forms.PropertyChangingEventArgs –> |
Event Arguments |
Event Arguments |
NOTOC MapSuiteFormsEdition ThinkGeo.MapSuite.FormsEdition UpdateDocumentation
