thinkgeo.mapsuite.silverlightcore.linestyles
ThinkGeo.MapSuite.SilverlightCore.LineStyles
This class is a collection of predefined styles and helper methods to create styles.
    • ThinkGeo.MapSuite.SilverlightCore.LineStyles
CreateSimpleLineStyle(GeoColor,Single,Boolean)
  • This method returns a LineStyle based on the parameters passed in.
  • None
  • Type:LineStyle
  • Description:This method returns a LineStyle based on the parameters passed in.
  • centerlineColor
  • centerlineWidth
    • Type:Single
  • roundCap
CreateSimpleLineStyle(GeoColor,Single,LineDashStyle,Boolean)
  • None
  • Type:LineStyle
  • centerlineColor
    • Type:GeoColor
    • Description:This parameter is the center line color.
  • centerlineWidth
    • Type:Single
    • Description:This paramter is the the center line width.
  • centerlineDashStyle
    • Description:This parameter is the dash style for the center line.
  • roundCap
    • Description:This parameter defines whether you want a rounded end cap.
CreateSimpleLineStyle(GeoColor,Single,GeoColor,Single,Boolean)
  • None
  • Type:LineStyle
  • innerLineColor
    • Type:GeoColor
    • Description:This parameter is the inner line color.
  • innerLineWidth
    • Type:Single
    • Description:This parameter is the inner line width.
  • outerLineColor
    • Type:GeoColor
    • Description:This parameter is the outer line color.
  • outerLineWidth
    • Type:Single
    • Description:This parameter is the outer line width.
  • roundCap
CreateSimpleLineStyle(GeoColor,Single,LineDashStyle,GeoColor,Single,LineDashStyle,Boolean)
  • None
  • Type:LineStyle
  • innerLineColor
    • Type:GeoColor
  • innerLineWidth
    • Type:Single
  • innerLineDashStyle
    • Description:This parameter is the inner line dash style.
  • outerLineColor
    • Type:GeoColor
  • outerLineWidth
    • Type:Single
  • outerLineDashStyle
    • Description:This parameter is the outer line dash style.
  • roundCap
CreateSimpleLineStyle(GeoColor,Single,GeoColor,Single,GeoColor,Single,Boolean)
  • None
  • Type:LineStyle
  • centerlineColor
    • Type:GeoColor
  • centerlineWidth
    • Type:Single
    • Description:This parameter is the center line width.
  • innerLineColor
    • Type:GeoColor
  • innerLineWidth
    • Type:Single
  • outerLineColor
    • Type:GeoColor
  • outerLineWidth
    • Type:Single
  • roundCap
CreateSimpleLineStyle(GeoColor,Single,LineDashStyle,GeoColor,Single,LineDashStyle,GeoColor,Single,LineDashStyle,Boolean)
  • None
  • Type:LineStyle
  • centerlineColor
    • Type:GeoColor
  • centerlineWidth
    • Type:Single
    • Description:This parameter is the center line dash style.
  • innerLineColor
    • Type:GeoColor
  • innerLineWidth
    • Type:Single
  • outerLineColor
    • Type:GeoColor
  • outerLineWidth
    • Type:Single
  • roundCap
thinkgeo.mapsuite.silverlightcore.linestyles.txt · Last modified: 2017/03/16 21:59 (external edit)
