thinkgeo.mapsuite.silverlightcore.areastyleadvanced
ThinkGeo.MapSuite.SilverlightCore.AreaStyleAdvanced
This class represents the advanced drawing options for area styles.
    • ThinkGeo.MapSuite.SilverlightCore.AreaStyleAdvanced
AreaStyleAdvanced()
  • This is the default constructor for the class.
  • None
FillCustomBrush
This property allows you to get and set a custom fill brush.
This allows you to use custom brushes to achieve effects such as linear gradients and bitmap fills. If you use any brush besides the SolidBrush, you would set it in this property.
thinkgeo.mapsuite.silverlightcore.areastyleadvanced.txt · Last modified: 2017/03/16 21:59 (external edit)
