thinkgeo.mapsuite.silverlightcore.layersdrawneventargs
ThinkGeo.MapSuite.SilverlightCore.LayersDrawnEventArgs
      • ThinkGeo.MapSuite.SilverlightCore.LayersDrawnEventArgs
LayersDrawnEventArgs()
LayersDrawnEventArgs(IEnumerable<Layer>,RectangleShape,Object)
  • None
  • layers
    • Type:IEnumerable<Layer>
    • Description:This parameter is the layers that were drawn.
  • worldExtent
    • Description:This parameter is the world extent you are drawing.
  • nativeImage
    • Description:This parameter is the GeoImage or native map image.
WorldExtent
This property gets and sets the world extent to draw.
NativeImage
This property gets and sets the GeoImage or native image we are drawing on.
Layers
This property gets and sets the layers that have been drawn.
thinkgeo.mapsuite.silverlightcore.layersdrawneventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
