GetDegreesMinutesSecondsFromDecimalDegree(Double)
GetDegreesMinutesSecondsStringFromDecimalDegree(Double)
GetDegreesMinutesSecondsStringFromDecimalDegree(Double,Int32)
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape)
E 36?20' 42N”.
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(PointShape,Int32)
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature,Int32)
GetDegreesMinutesSecondsStringFromDecimalDegreePoint(Feature)
GetDecimalDegreeFromDegreesMinutesSeconds(String)
GetDecimalDegreeFromDegreesMinutesSeconds(DegreesMinutesSeconds)
GetDecimalDegreeFromDegreesMinutesSeconds(Int32,Int32,Double)
GetDistanceFromDecimalDegrees(PointShape,PointShape,DistanceUnit)
GetDistanceFromDecimalDegrees(Feature,Feature,DistanceUnit)
GetDistanceFromDecimalDegrees(Double,Double,Double,Double,DistanceUnit)
GetLongitudeDifferenceFromDistance(Double,DistanceUnit,Double)
GetLatitudeDifferenceFromDistance(Double,DistanceUnit,Double)
dxo=(Double,Double,Double,DistanceUnit,Double)
eBo=(PointShape,PointShape,Int32)
eRo=(Double,Double,Double,Double,PointShape,DistanceUnit)
eho=(Double,Double,Double,Double,PointShape)
exo=(Double,Double,DistanceUnit)
