A
This class represents the advanced drawing options for area styles.
This class is a collection of predefined styles and helper methods for creating styles.
B
This class draws the background of the map.
The abstract class from which area shapes, line shapes, and point shapes inherit from.
This class represents the parameters passed in through the BuildingIndex event in ShapeFileFeatureSource class.
C
This class represents a single class break.
This class represents a style based on class break values.
This static class provides a conversion method to go to and from different units.
D
This class represents the column information specific to a DBF column.
This class allows you to display information by drawing points on an area based on a value from the features data.
E
A strongly-typed resource class, for looking up localized strings, etc.
This static class exposes a number of helpful methods when dealing with extents.
F
G
This class represents a font that is used to label features on a GeoCanvas.
This class represents an image you want to use on the GeoCanvas.
This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
This class is a convenient way to access a predefined set of geographic colors.
This gradient style is a new style with the concept of GradientBrush. By specifying the LowerValue and its color, as well as the UpperValue and its color, we can set the color of each feature based on a column value using linear interpolation.
This class represents a Layer backed by a group of layers.
I
This layer is backed by memory and is typically used for temporary features.
L
This class represents the location of a piece of a label that may be drawn.
This class represents a candidate for labeling.
This class is the base class for all types of Layers.
This class is the style used to draw lines.
This class is a collection of predefined styles and helper methods to create styles.
M
This class represents a base Matrix which encapsulate the tile caculation logics.
This MultipleFeatureSource is a special FeatureSource which holds a bunch of FeatureSource.
This class represents one or more point shapes.
O
P
Q
This is a helper class that allows you to execute various queries.
R
This class represents a single Regex Match statement and styles to draw.
This class allows you to draw features differently based on regular expression matching.
This class represents a closed ring of points.
S
This class represents a Layer backed by a Shape File.
This class represents a FeatureSource backed by ESRI a Shape File.
This class stores simple label information used in the PositionStyle.
This class is a convenient way to access a predefined set of simple colors.
This class is a convenient way to access a predefined set of standard colors.
This class represents the event arguments for the StreamLoading event.
This abstract class is the root for all styles used for drawing features.
T
V
This class represents a single value to match and styles to draw.
This class allows you to match a value with data in the feature to determine how to draw that feature.
W
Z
C
D
This structure represents a degrees, minutes and seconds value.
This structure represents the drawing of a rectangle in screen coordinates.
F
G
R
S
V
A
Units describing various ways you can measure areas.
B
In a class break style, this enumeration determines whether the break includes or excludes the value entered in the break.
This enumeration represents whether an index should be rebuilt or not.
This enumeration represents whether a record ID should be rebuilt or not.
D
This enumeration represents the column type in the DBF.
Units describing various ways you can measure lengths.
This enum is used to describe some choice when exception hanppens during drawing Layers or Overlays.
This enumeration specifies the type of font style for drawing text.
This enumeration represents the graphics unit.
This enumeration represents the drawing level used in the GeoCanvas.
This enumeration specifies how to join consecutive line or curve segments.
G
Units describing the way geographies are stored in a data source.
L
This enumeration defines the different labeling duplicate rules.
This enumeration defines the rules for overlapping.
This enumeration specifies the style of dashed lines drawn with a GeoPen object.
M
The enumeration represents which mode will use for map resize.
O
P
This enumeration defines panning directions.
This enumeration determines whether the brush or the pen draws first.
This enumeration determines the label placement when labeling point features.
This enumeration defines the different types of PointSymbols that can be drawn.
This enumeration defines how a PointSymbol will be drawn.
Labeling Location Mode for polygon
Q
R
Defines values represent which kind of color will use for randomly.
This enumeration defines the matching criteria for regular expression matching.
This enumeration provides some options when querying a feature.
S
This enumeration represent read only or read-write nature of a Shape File.
This enumeration represents the types stored in the Shape File.
This enumeration describes the type of validation test to run on shapes.
Specifies which algorthm will be use to simplify.
This enumeration represents the spline type for labeling.
An enumeration describing the place to start on a line when doing certain operations.
T
W
This describes a set of enumerations that list the valid types of geometries.
This enumeration represents the byte order that well-known binary will be written in.
