thinkgeo.mapsuite.silverlightedition
ThinkGeo.MapSuite.SilverlightEdition
SilverlightEdition
Classes
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
B
  • BingMapsOverlay
    This class represents the BingsMapOverlay which requests images from image server of Bing Maps.
  • BingMapsZoomLevelSet
    This class represents the zoom levels used by Bing Maps.
C
D
E
  • EditInteractiveOverlay
  • ExtentChangedEventArgs
    This class represents the event argument for the ExtentChanged event.
  • ExtentChangingEventArgs
    This class represents the event arguments for the ExtentChanging event.
  • ExtentInteractiveOverlay
    This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
F
G
I
  • InMemoryMarkerOverlay
    This class represents a MarkerOverlay object that dynamicly creates markers from the InMemory features.
  • InteractionArguments
    This class encapsulates the information and simple method for interative actions.
  • InteractiveOverlay
    This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
  • InteractiveResult
    This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
L
  • LayerOverlay
    This class represents an Overlay that contains layers such as ShapeFileFeatureLayer, InMemoryFeatureLayer..
  • LogoMapTool
    This class represents an company logo image that displays at the lower-right corner of the map.
M
O
  • OpenStreetMapOverlay
    This class represents the OpenStreetMapOverlay which requests images from OpenStreetMap's image server.
  • Overlay
  • OverlaySwitcherMapTool
    This class represents a panel in the upper right corner on the map which contains a list of map overlays that added in OverlaySwitcher Overlay collection.
P
  • PanZoomBarMapTool
    This class represents the panning and zooming panel in the upper left corner of the map.
  • PointMarkerStyle
    This class represents the ordinary point marker style.
S
T
V
W
Structures
Enums
B
  • BingMapsStyle
    This enumeration specifies the map types available from Bing Map.
C
  • ControlPointType
    This enumeration specified the control point type when editing a shape. The deafault value is None
D
  • DrawMode
    This enumeration represents the drawing mode for rendering map.
G
  • GoogleImageFormat
    This enum represents the Google Image Format requests by Google's static API.
  • GoogleMapType
    This enum represents the Google Maps Type requests from Google's static API.
I
  • InteractiveOverlayDrawType
    This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
M
  • MouseCoordinateType
    This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
O
  • OverlayDrawType
P
  • ProcessOtherOverlaysMode
    This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
T
  • TileType
    This enumeration specifies whether the overlay uses tiling.
  • TrackMode
    TrackMode enumeration sets how the map will react to user interaction.
  • TransitionEffect
    This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
W
Interfaces
thinkgeo.mapsuite.silverlightedition.txt · Last modified: 2017/03/16 21:59 (external edit)
