thinkgeo.mapsuite.silverlightedition.vertexaddingeditinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.VertexAddingEditInteractiveOverlayEventArgs
Provides data for the VertexAdding. event.
      • ThinkGeo.MapSuite.SilverlightEdition.VertexAddingEditInteractiveOverlayEventArgs
VertexAddingEditInteractiveOverlayEventArgs()
VertexAddingEditInteractiveOverlayEventArgs(Boolean,Feature,Vertex)
  • cancel
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • addingVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex to be added.
AffectedVertexFeature
This property gets or sets the Feature to be used to move vertex.
AddingVertex
This property gets or sets the vertex to be added.
Cancel
thinkgeo.mapsuite.silverlightedition.vertexaddingeditinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
