thinkgeo.mapsuite.silverlightedition.mouseleftbuttondownmarkeroverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.MouseLeftButtonDownMarkerOverlayEventArgs
Provides data for the MarkerOverlay mouse events.
      • ThinkGeo.MapSuite.SilverlightEdition.MouseLeftButtonDownMarkerOverlayEventArgs
MouseLeftButtonDownMarkerOverlayEventArgs()
  • Initialize an instance of the MouseLeftButtonDownMarkerOverlayEventArgs class.
MouseLeftButtonDownMarkerOverlayEventArgs(Marker,Point)
  • Initialize an instance of the marker that the mouse event raised. identifier current mouse position where current mouse is.
  • currentMarker
    • Type:Marker
    • Description:The marker that the mouse event raised.
  • mousePositionInPixel
    • Type:Point
    • Description:The screen coordinate where current mouse position is.
CurrentMarker
Gets or sets the marker that the click event raised.
MousePositionInPixel
Gets or sets current mouse position in screen coordinate.
  • Type:Point
thinkgeo.mapsuite.silverlightedition.mouseleftbuttondownmarkeroverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
