thinkgeo.mapsuite.silverlightedition.vertexremovededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs
Provides data for the VertexRemoved. event.
      • ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs
VertexRemovedEditInteractiveOverlayEventArgs()
VertexRemovedEditInteractiveOverlayEventArgs(Feature,Vertex)
  • affectedVertexFeature
    • Type:Feature
    • Description:This parameter specified the affectedVertex feature property.
  • removedVertex
    • Type:Vertex
    • Description:This parameter specified the target vertex removed.
AffectedVertexFeature
This property gets or sets the Feature to be used to remove vertex.
RemovedVertex
This property gets or sets the vertex removed.
thinkgeo.mapsuite.silverlightedition.vertexremovededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
