thinkgeo.mapsuite.silverlightedition.mousecoordinatetype
ThinkGeo.MapSuite.SilverlightEdition.MouseCoordinateType
This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
Map.MousePosition.MousePostionType property uses this enumeration to determine which position type to appears when the pointer is moving around the map.
Items
LongitudeLatitude
  • Summary:Defaut mouse position type, format: “longitude, latitude”.
LatitudeLongitude
  • Summary:Defaut mouse position type, format: “latitude, longitude”.
DegreesMinutesSeconds
  • Summary:Appear degrees, minutes, seconds, format: “Degressº Minutes'' Seconds'”.
thinkgeo.mapsuite.silverlightedition.mousecoordinatetype.txt · Last modified: 2017/03/16 21:59 (external edit)
