thinkgeo.mapsuite.silverlightedition.featurerotatededitinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.FeatureRotatedEditInteractiveOverlayEventArgs
Provides data for the FeatureRotated. event.
      • ThinkGeo.MapSuite.SilverlightEdition.FeatureRotatedEditInteractiveOverlayEventArgs
FeatureRotatedEditInteractiveOverlayEventArgs()
FeatureRotatedEditInteractiveOverlayEventArgs(Feature)
  • rotatedFeature
    • Type:Feature
    • Description:This parameter specified the feature rotated.
RotatedFeature
This property gets or sets the Feature rotated.
thinkgeo.mapsuite.silverlightedition.featurerotatededitinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
