thinkgeo.mapsuite.silverlightedition.worldmapkitprojection
ThinkGeo.MapSuite.SilverlightEdition.WorldMapKitProjection
This enumeration represents which projection will use for world map kit.
The Default item is the same as DecimalDegrees.
Items
Default
  • Summary:The same as DecimalDegrees.
DecimalDegrees
  • Summary:DecimalDegrees, for example, the EPSG:4326 is decimal degrees.
SphericalMercator
  • Summary:SphericalMercator, for example, the Google Maps use EPSG:900913 is spherical mercator.
thinkgeo.mapsuite.silverlightedition.worldmapkitprojection.txt · Last modified: 2017/03/16 21:59 (external edit)
