thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs
Provides data for the TrackStarting. event.
      • ThinkGeo.MapSuite.SilverlightEdition.TrackStartingTrackInteractiveOverlayEventArgs
TrackStartingTrackInteractiveOverlayEventArgs()
TrackStartingTrackInteractiveOverlayEventArgs(Vertex,Boolean)
  • startingVertex
    • Type:Vertex
    • Description:This parameter specified the started vertex when tracking shape action is being to start.
  • cancel
Cancel
StartingVertex
This property gets or sets the started vertex when tracking shape action is being to start.
thinkgeo.mapsuite.silverlightedition.trackstartingtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
