thinkgeo.mapsuite.silverlightedition.trackendedtrackinteractiveoverlayeventargs
ThinkGeo.MapSuite.SilverlightEdition.TrackEndedTrackInteractiveOverlayEventArgs
      • ThinkGeo.MapSuite.SilverlightEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs()
TrackEndedTrackInteractiveOverlayEventArgs(BaseShape)
  • trackShape
    • Type:BaseShape
    • Description:This parameter specified the tracked shape.
TrackShape
This property gets or sets the tracked shape.
Cancel
This property gets or sets the action to be canceled or not. This property has no use any more, please use the it in the TrackInteractiveOverlay.TrackEnding event.
thinkgeo.mapsuite.silverlightedition.trackendedtrackinteractiveoverlayeventargs.txt · Last modified: 2017/03/16 21:59 (external edit)
